- Jan 14, 2007
When your Emerson has done some mild chores, and is no longer FRESH HAIR POPPING CRISPY SHARP, but still paper cutting/shaving sharp, how do you proceed?
To me, following the typical method of sharpening till burr, then removing it from the back, seems overkill, and a waste of metal at this early stage.
Currently, I'll just wait until the edge has enough boogery spots that it's ripping paper, then do a full on sharpen with burr. If I need an edge right away, I might lightly hone at a very slight microbevel with fine ceramic, alternating both sides, just kissing the apex. Raising the angle guarantees I hit the apex without creating a burr.
Don't seem to get much luck matching the original edge angle when using fine abrasives like ceramics, plus they are prone to creating those annoying work hardened wire edges when you get carried away. And it's hard to tell when I've actually reached the apex that way, unless I form a burr, which defeats the purpose of "honing" vs "sharpening."
Microbeveling a thick chisel edge isn't necessarily optimal cuz of the already obtuse angle, but it removes so little metal that it doesn't seem to affect the cutting, and it seems to be less wasteful than grinding away the whole edge just for maintenance....
So how do you guys do your touch ups? Asking MAINTENANCE here, not full SHARPENING.
Same as sharpening?
Slight microbevel honing?
Stropping?
What abrasives/systems/grits?
What are your thoughts on how these methods affect the life of the knife/metal waste?
Thx!
Same as sharpening?
Stropping?
Thx!
