I just thought this was a blade forum, not a spelling forum.You will get more search results by spelling it q-u-e-n-c-h.
I have done a search and can't seem to find anything on this, so please don't beat me up. Can you use burnt motor oil for quinch? I have used it to temper springs and worked perfect.
You know, bud, I don't care how you spell it. I was trying to help, though, to get you more search results. You usually get more results if you spell it correctly. Take the chip off your shoulder, for cripes sake.I just thought this was a blade forum, not a spelling forum.
I had already done a search and it knew what I mentioned. There were threads all about all kinds of oils but none about motor oil. I did another search on another forum and found that is great for metal quench, because it adds extra carbon. Just have to use in well ventilated areas. The additives produce dangerous fumes.Welcome to Shop Talk wwillimon. Fill out your profile so we know where you live and a bit about you. It will help you get better answers.
What Fitzo's point was that if you search Quench Oil you will find hundreds, maybe thousands, of threads and discussions on the subject. The general best oil for most steels is Parks #50.
There is the Custom Search Engine in the Stickys that will find any subject we have ever talked about here.
Sir I apologize for my response. I guess I was just expecting someone to give me some kind of smart answer. Deeply sorry!!You know, bud, I don't care how you spell it. I was trying to help, though, to get you more search results. You usually get more results if you spell it correctly. Take the chip off your shoulder, for cripes sake.
Accepted and moved on. Thank you, and good luck with your question.Sir I apologize for my response. I guess I was just expecting someone to give me some kind of smart answer. Deeply sorry!!
For the record, adding extra carbon is a myth.I had already done a search and it knew what I mentioned. There were threads all about all kinds of oils but none about motor oil. I did another search on another forum and found that is great for metal quench, because it adds extra carbon. Just have to use in well ventilated areas. The additives produce dangerous fumes.
You catch more flies with honey than...motor oil.I just thought this was a blade forum, not a spelling forum.
