- Jul 16, 2005
Get one. Oh, you want more?
Yes, its carved. I like it, it adds an extra bit of soul to the knife.
The blade finish is a villager type, but does not hide any flaws. The grip is carved, and is shaped different than any other khukuri I have, a long rounded triangle in cross-section with the broad side down at the finger side. The grip was a bit rough and I must admit to using a bit of 250 grit paper to remove some small imperfections, but I left all the carving as it was. I do use a damp cloth after sanding, to both raise the grain and to have a bit more moisture when I seal it with the oil. I then oiled the grip.
I like to use Birchwood-Casey Tru-Oil on my wood grips and stocks. Its a blend of polymerized linseed oil with other natural (and maybe unnatural too) oils. It seals and fills the grain, and is easy to blend in for minor repairs. Depending on the final steps it can be high gloss or a more matt finish.
Either the wood or the finish used in making the knife caused the Tru-Oil to take much longer to dry than usual. Sunlight seemed to help it kick-off and harden.I went for a high gloss to match the original sheen.
My scale is busted so I used a fish scale to get a weight of 25-26 oz.
In the chop test I hacked a seasoned and dry 3 piece of blackthorn. As you may know that is one tough wood. I did not sharpen the blade and went to town with about eight cuts. Clean cuts, and NO bends, folds, chips or dullness on the blade after this test. Not even marking after I wiped it down!
I thought the grip shape might be an issue, but it was not. No tendency to twist or turn in the had at all. As the name says, the balance is different, a bit towards the tip, but also deeper in the belly. I reminded me a bit of my boomerang in that way. The wonderful tiger (I think) head is a useful hand stop but does not get in the way in use.
Note the markings on the blade are reversed side to side from my others
This is both a collector and a user!
http://postimg.org/gallery/324qs85gu/
