Heres some super quench recipes, from Rob Gunter and theforge, and some data on HC spikes
5 pounds salt, 32oz blue Dawn dishwashing liquid, 8oz Shaklee Basic
I wetting agent, add water to make 5 gallons of solution.
Stir it up to get it moving before you quench. Don't quench anything
with more than 45- 50 points of carbon.
You can also use Simple Green as a replacement for the Shaklee
product. You can get this at Wal-Mart.
>5 gal water
>5lb Salt
>32oz Dawn (blue) dishwashing liquid
>8oz Shaklee Basic H (or other surfactant of appropriate quantity for 5 gal mix)
>Will harden mild steel to Rockwell 42-45 (in spite of common wisdom that
>says you can't harden mild steel).
That's an old formula.
Dawn is now a "concentrate". Use the 28oz bottle.
Jet-Dry "liquid rinse agent" can be substituted with terrific
results (and it's a lot easier to find) for the Shaklee product(s). Use
the UNSCENTED 7oz bottle.
The Jet-Dry (or whatever you use for a rinse agent) does something
chemically to the surface of the steel. It allows the salt in the mix to
start attacking it as soon as it hits the air - make sure you have a LOT of
clear water to rinse in ready at hand.
Quench a chunk of low-carbon scrap stock in it, and just set it
aside. You can *watch* the salt eat into it.
Jet Dry, Calgon, and other surfacants are wetting agents. They break
down the surface tension of water allowing it to make contact with a
meterial. We've all dipped a cold piece of metal in water and seen a
bubble-like "skin" form with dry metal under it. This is surface tension
trapping a layer of air, it makes a fair heat shield.
In a quench, steam will form a similar surface "skin" and prevent full
contact with the water, insulating the steel from a proper chill.
Wetting agents prevent the "skin" from forming.
Detergents do a somewhat similar job, they're emulsifiers allowing oils
and water to mix. This prevents any oily residues from the fire from
forming a "heat shield" surface layer.
The salt in the water raises the boiling point and causes a faster,
harder chill in the steel. In effect but not exactly, it raises the
specific heat of the water and draws the heat from the steel faster.
Railroad Spike Info:
From a section of High Carbon RR spike sent in for analysis to U.S. Steel, as
there had been several people inquire ( as well as satisfying my own curiosity ).
Here are the results:
Carbon - .296 %
Manganese - .68 %
Phosphorous - .016 %
Sulfur - .038 %
Silicon - .244 %
Copper - .287 %
Nickel - .09 %
Chrome - .13 %
Tin - .001 %
Aluminum - .005 %
Vanadium - .022 %
Cobalt - .008 %
High carbon spikes were made exclusively starting in or around 1974 to replace the
low carbon spikes currently out there, and were generally just iron and carbon
(with a couple trace elements thrown in for special areas).
Steve Rabuck
Beloit, WI
(theforge)
For High-Carbon Steel Track Spikes:
Process: Steel shall be made by one or more of the following processes:
open-hearth, acid-bessemer, electric-furnace, basic-oxygen.
Chemical Composition:
Acid-Bessmer Other Process Carbon, min. percent 0.20- 0.30
Copper, when specified:
0.20%
Tensile Properties:
Tensile Strength, min. psi. ............................70,000
Yield Point, min. psi. ....................0.5 tensile strength
Elongation in 2 in., min percent.......................... 25
Machinery's Handbook
Marking:
Manufacturer brand and the letters "HC" indicating high-carbon, and when copper is
specified the letters "CU" will be added.
