- Aug 28, 2009
So the other day I was given an 18" chunk of railroad track to use as an anvil till I find a real one. It was roughly shaped, but still needs some work, okay a lot of work.
In return for the loan I get to shape it in to an anvil like shape. Going by the measurements I have narrowed it down to a heavy gauge rail, the base is 6" across, the head is 3" across, and it has a height of 7 1/8", so by the charts Ihave found that would make it either section index 13228 or 13128. that would make them 132lbs/yd or 131lbs/yd making my section come in around 66lbs.
Believe it or not it seems to have really good rebound, dropping the hammer head onto it from 6" it rebounds approximately 3". It is also an end piece so one end is square and sharp cornered. Aside from shaping a horn, is there any thing else I should do to it? Yes the head is slightly rounded, but I doubt that I can get it flat with an angle grinder. I do have a bit of time before I could use it, temps here wont be warm enough for a few months to start hammering outside
