OK, I looked at my s30v blade a little longer and found a small chip; reason enough to put it back on the SharpMaker.
I painted both bevel sides with a Sharpie, and then hit the corners of the brown stones just working one side up and down quickly for a few minutes. Then I checked the progress and all the marker was gone (at 10X), but no burring could be felt (by stropping on my thumb pad). So I continued for several more minutes, still no burring.
Then I leaned a 325 mesh, blue duosharp DMT against the rods and continued on the same side for about a minute. Under magnification I could see that the DMT had completely worked the bevel on that side, but still no burring.
Then I moved the DMT to the opposite side of the SharpMaker and worked the opposite bevel for about two minutes. Then I stropped the edge on my thumb and there was a fairly obvious burr.
Then I worked the burr side, back on the brown rods just on one side to see if I could burr the opposite side. After a few minutes, nothing. So I retried the DMT and recreated a burr again.
Conclusion, I could not create a burr (that could be felt) with the corners of the brown rods by working one side of the SharpMaker on this knife which is BOS s30v. However, I could using a DMT.
Added later:
I continued to dress the edge with the brown stones on both sides (in the conventional side to side manner) to take out the DMT scars and finish the edge. I noticed as the edge got more refined and sharper, I began to detect and chase a burr. I could flip it back and forth and remove it on the corners by raising the angle. With the burr gone the edge is tree topping arm hair now.
New conclusion: I know nothing!
