I still don't like how folders rely so much on thing piece of plastic and brass in terms of smoothness.
phosphor bronze and teflon washers, i don't think it gets smoother than that. what do you like ?
I've had them open before - what were you doing? Polishing the plastic washers?I opened my triad Recon 1 a couple of times to do a blade reshaping and coating mod. Just wondering why you were inside your Raj 2?
My mistake.
I don't like the washers, because they have ruined each "heavy use" folder I've had. I end up messing them up, and they make the blade close off centered wich can drive you mad.
I had it opened up last week to help out a fellow forum member with blade centering issues.
Agreed :thumbup: Why do they even put nylon/plastic/teflon washers on decent folders anyway?
I modded my Recon 1 but the tolerances were looser after removing the Telon coating and very slight blade play side to side.
You had bladeplay issues just from removing the coating? Were you able to get rid of the play by tightening the pivot screw? How did you remove the coating? I'm surprised because I thought the coating was so thin that removing it wouldn't make a difference, or only a tiny difference that could be solved by tightening the pivot.
