I don't have any pictures, but can describe the knife as it appears to me. It's got "full" steel liners. -Nested. No holes, fills the entire foot-print of the handle. It has the two pins, one at the lock pivot, and one at the blade-stop. Then it has three screws on each side of the handle for a total of six. The screws are staggered slightly on each side of the handle. I haven't stipped the knife down, but it appears that the back-spacer is removable -if you were to disaseble the knife. The pivot is large, and the female side of the pivot is larger than the screw head. The stud/wave is removable via screw. The lock appears to have a basic large spring in it similar to other lock-backs. The lock-bar itself appears substantial. Will come with two pocket clips, one will fit each side depending on your choice of carry. Pocket-clips have three screws.
Mine has slight blade-play if you grip the blade at the tip. If you grab the blade at about the half-way point, you can't feel the play. Depressing the lock is not hard, as I've heard others mention. When the lock is fully depressed the blade will swing freely. It is realatively easy to open with one hand using the stud like a normal sized lock-back. The wave works well, and it can be flicked opend pretty easily once you get the blade started moving. Closed retention is similar to other lock-backs.
All in all, I feel this is a great knife if you want something of this size. -I guess there's not exactily a lot of compitition for it though. I have done light chopping and basic cutting with mine. I think it's a handy, perhaps under-rated, "tool" for most out-door uses, but I've yet to really push it hard. My one issue is that when I hold it in a full hammer-grip at the main hold-point (just below the guard), I can't avoid depressing the lock with the web of my thumb. When the lock is depressed even slightly, it loosens the lock-up. If I run my thumb up the spine onto the thumb-stud, this isn't an issue. Also, choking up on the knife so that the index-finger is above the guard is fairly comfortable, as is gripping it at the mid-point and low on the handle for chopping. The steel seems to hold a resonable edge. I've had less rust than expected, and nothing uncleanable yet.
