I used a basic (no ramp/soak) controller on my first oven. I have built 4 more since with ramp/soak controllers and would definitely say they are worth the extra money (I pay for the ramp/soak units, but have several of the more basic units in my store of scrounged stuff).
The units I've been using are the Omega CN7823
http://www.omega.com/pptst/CN7800.html
or the AutomationDirect Solo SL4848VR
http://www.automationdirect.com/adc...ers/1-z-16_DIN_Size_(SL4848_Series)/SL4848-VR
They are both the same controller with different badges, at least as far as I can tell.
I can't comment on the Auber Instruments units because I am in the UK and have not tried them (both AD and Omega have UK suppliers).
I did spend quite a long time looking for suitable controllers at an affordable price before settling on the AD unit. I use process controllers at work, so I'm reasonably familiar with controllers in general.
One thing I particularly like about the AD/Omega, is that it can autotune at 4 different temperatures and will then automatically select the set of PID values for the tuning temperature closest to your target temperature. I find that the optimum PID terms for each oven are different at Austenitizing and Tempering temperatures, so this actually gives better control over the full range than just having one set of PID terms. I'm also (still) intending to build a tempering-only oven to work off the same control box and eliminate the need to wait until the main oven cools before I can start tempering.
If money is really tight and you are only going to be treating the simpler steels for a while, you can fit a cheap basic controller from ebay and upgrade to the ramp/soak controller when you need it. Terminal positions may change, but the wiring is otherwise exactly the same for ramp/soak as for a basic controller. Stick to a 48mm x 48mm unit and allow an extra 2 inches of length on the wires to accommodate any changes in length or terminal layout. Like most other electronics, controllers tend to get better and cheaper with time.
