I bought a Randall 12-9 merely because another thread made curious how Randall Made Knives basically compare to a contemporary design. I used a Busse FBM LE for 6 years. It was a so so chopper. It was a little too thick with a steep edge that would not penetrate hard woods well, plus, it had a flat grind and would basically gall onto the tree when you did manage to get a deep cut in a softer wood. The steel was ok, would chip like any other high quality knife that hit a rock in the process of being used in the field. The blade material, marketed as INFI, relies on the steep bevel to hold its edge, if you take it down a bit to improve penetration, it goes dull like any other quality production knife. I used it for 6 years and chopped hundreds of small trees that grow out of control on my rural property. It was thick, hence strong. Finally sold it because it took too much energy to use and found it unproductive in the field. Next I used a Bill Buxton made of forged 52100, it was was much better, and held an edge like no other. I did not take Bill's advise and ordered an 8 instead of a 9 inch blade, and it was a bit too short.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]As a result of the other thread I decided to try a Randall 12-9 made of a very high quality Swedish tool steel. I used it to cut a few dozen trees. It was the most effective chopper of the three. The cuts were deep even in hard woods, the hollow grind did not gall, the edge held up better than the Busse, but chipped a bit easier when the edge came in contact with a rock than the Bill Buxton. I used in an abusive manor in an effort to cause a break at the tang, which I presume is approximately 1/2 X 1/4 X 4.75 inches as it appears to be based off a #14 CDT grind. It seems one would have to break this knife on purpose in order to effectuate failure. The Randall and the Bill Buxton are expensive, and expensively made. The Busse appeared to be mostly machine made, but high priced. My point is, Busse prices into its MSRP an abuse warrantee. The FBM LE in 2007 was a simple construction $375 knife that actually retailed for $697 sans a sheath. The price of the hand forged Randall and Buxton do not reflect a warrantee for abuse, so the buyer has to self insure the knife under certain circumstances, but they are forged, and the advantage to a carbon steel blade seems to be the same as on the cranks of a mountain bicycle, forged units require less material to create the same amount of strength compared the those CNC'd or chucked, machined, and ground, making this production method perfect for a hollow grind blade. The cost of self insuring the knife for abuse versus having it packed into the retail price would be a consideration a purchaser would have to weigh relative to their own personal comfort level, either you pay upfront, or only if you break it.
A pic of the Busse after my gunsmith ground down the glass breaker.
[/URL][/IMG]
A pic of the Bill Buxton when it was new
[/URL][/IMG]
