Welcome Knife Knut
I the #1 seller for HI is the 15" Ang Khola. This is what most people who start collecting HI khuks start with. It will be heavy enough to chop through most things, light enough to pack, strong enough to pry with, and of a familiar size to those that have used larger bowies in the past (9-10" blade with the remainder being handle).
The handles are rugged as rugged can be. They come in horn or wood. The horn tends to look more "exotic" while the wood, IMHO, is more stable and can be customized a little more easily.
As far as sharpening goes, the khuk responds well to most any kind of sharpening method. It's a good carbon steel that will get sharp via stone, sharpening steel, or belt sander. Most folks seem to like to convex the edge even more with a belt sander. Personally, I do all of my sharpening by hand with stones, steels, sand paper, and leather. The khuks have a Rockwell of around 57-60 at the "sweet spot" (about an inch to inch and a half from the tip and will extend 3"-5" depending on the khuk shape and length). The tip and re-curve will run slightly softer as the khuk edge is designed to dent and roll when you strike something hard rather than chip. Therefore, you shouldn't need any fancy diamond hones to keep it sharp.
You can e-mail Yangdu at
himimp@aol.com if you would like to find the "perfect" khuk. She's a wonderful lady that is a pleasure to do business with. Or, you can wait for the Deal of the Day. Every so often (maybe a couple times a week give or take), Yangdu will post up some fantastic deals. Some of these knives are one of a kind items that don't come along often. Many of them are blems with just a little bit of rust or a dinged up scabbard. All of them come with HI's lifetime warranty. It's a good way to save big bucks on a khuk. They are usually around 1-3pm Eastern time. You gotta be quick sending your e-mail though. These babies go fast
Some of the more common khuks that show up that might be best suited for your needs are: 15-18" AK's, 17" M-43 (very curvy...not the best starter khuk, IMHO), 16.5"-18" WWII. 16.5" Chiruwa AK (the kind with the slab handles pinned to the side of the tang.)
Once again, welcome
