Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
I finished these two Thursday, but haven't had time to shoot photos until tonight.
The blades are 1095, hilts and pommel nuts are sterling, handles are ebony. Blades are fully hardened and tempered.
The 50 cent piece is for scale.
The rapier is 15:1 scale and the parrying dagger is 24:1.
To get an idea of how close the tolerances are, the handle on the dagger is .05" at its widest....and the tang is .03" thick. That makes the handle walls .01" thick.....about as thick as three sheets of white printer paper. The tapered handle ends are only about one sheet of paper thick.
Specs:
Rapier-
BL -3.4"/88mm
OAL - 4.7"/118mm
Blade width and thickness ( mid blade) - 0.10 "/2.5mm -.03"/.8mm
Diamond cross-section
Dagger -
BL - .7"/18mm
OAL - 1.0"/26mm
Blade Thickness ( mid blade) - .035"/.90mm - .02"/.5mm
Specs:
Rapier-
BL -3.4"/88mm
OAL - 4.7"/118mm
Dagger -
BL - .7"/18mm
OAL - 1.0"/26mm
