OK. I invested in a Sharpmaker. But it was pure hell trying to sharpen my RAT-3. I listened to the experts here and decided I needed to re-profile the edge from 40deg to 30. So...... I invested in a Lansky Deluxe.
I took the Extra Course hone, clamped the knife in well (that was a challenge because of the flat grind, until I learned to clamp it on the 90deg non-ground area near the handle), and started grinding at 17 degrees.
Then, I ground some more at 17 degrees. Then, some more. Several hours and about 300 strokes later, I still had a little of the old profile near the edge! I was so tempted to plug in the Milwaukee 4" grinder but I didn;t want to mess up any of my grinding disks!!!!! Good Lord....either that D-2 is tough, or I don;t know what the hell I'm doing.... or both.
I finally left the tiny bit of old profile on there (especially near the tip of the blade, where it's thickest), smoothed the newly-profiled 17 degree edge out through the Course and Medium stones, then put a 20 degree edge on with the Fine and Extra Fine stones. It still isn't sharp. So I went to the Shaprmaker at the 40 degree setting. It aint sharp.
I'm not giving up....I'll plug in the Milwaukee before I give in. But I would like some input if you fellows wouldn;t mind. Meanwhile, I'm going to join a nearby health spa, pump some iron, and bulk up before I tackle that little RAT 3 again.
Oh. And I've worn that Extra Course down enough to feel it. Should I invest in a course diamond for the Lansky to re-profile edges? I'm thinking maybe if I add some sand-bags to my shoulders, it might give me enough extra weight to bear down and get that edge cleaned up.
