Raven
Just came across the Raven with the Krylon scales.....had never seen before. Is it Emerson quality or does it fall into their Hard Wear line? It looked like a nice knife and thought I would ask.
Thanks for the help,
JT
The Raven is not part of the Hard Wear line. It existed long before the Hard Wear series was introduced. The Raven is considered as a typical higher quality Emerson knife with a different handle design. I just picked up a Raven tanto in satin finish and it is very nice. It is lighter than the normal G-10 series.
Yup, there is nothing wrong with the ravens, there were g-10 ravens brought out not long ago too.
Thanks a bunch for the info. I am somewhat new to Emerson and had never run across that particular model. How does it compare to the Mach 1? I also came across this model and was curious if anybody had any history with/on it? Again, thank you all in advance for your help.
JT
Thanks a bunch Rick......really helps to compare side by side. Blades look VERY similar......which handle ergo/material do you prefer? The Mach 1 or the Raven?
Appreciate the help,
Cheers,
JT
No problem man. The blade on the Mach 1 is a bit wider than the raven, my pic shows the Mach 1 at an angle so it looks thinner than it is. Overall I prefer the Mach 1 ergos over the raven, and I just like G10 over most materials but the Raven's Kydron handles are still nice and grippy.
Rick
