Joe's dead on about the video, but I find their book much more convenient, since it can go wherever the sharpening is.
I've been using the deluxe kit for about a year and here's my pro's and con's:
Pros - extremely fast steel removal for re-profiling, difficult to screw up if you follow the directions and don't rush, one of the best steels around, near mirror finish with the fine stone, no oil/water to deal with, scary sharp edges, well built.
Cons - bulkier than many sharpeners, can't handle serrated edges, the dust is really messy (not as bad as oil/water though).
I've had 2 problems using mine. They're relatively minor, but I wonder if anyone else has them. The first is that the guides wear out faster than I'd prefer since they also rest on the hones. I tried to keep less pressure on the guide (as compared to the knife), but I usually ended up with the guide coming off the hone, thus rolling over the edge - back to square one. As a result of the wearing, repeated uses seems to lead to shallower angles. Has anyone found a way around this?
The other may be due to my technique. Almost every knife that I've sharpened ends up with a bevel that becomes shallower as you approach the tip. This is quite apparent, since the width of the bevel usally is about twice what it is near the handle. So the angle is much smaller near the tip, resulting in a weaker tip than the blade originally had. Unless I'm missing something, the only solution I can see is if the guides where shaped to match the blade's profile, which would mean a guide specific to each knife. That's not practical. Does anyone have the magic hammer you can hit me in the head with? Can't help but think I'm doing something wrong...
Overall, it's a great system and I highly recommend them. But if I'm just touching up an edge, I use a Sharpmaker. Does just as good with getting the last bit of sharpness out and takes less setup.
With both an RES system and Sharpmaker, I believe I can handle almost any sharpening need.
Ray
Knowledge without understanding is knowledge wasted.
Understanding without knowledge is a rare gift - but not an impossibility.
For the impossible is always possible through faith. - Bathroom graffiti, gas station, Grey, TN, Dec, 1988
AKTI Member #A000831
[This message has been edited by Codeman (edited 04-14-2000).]
