RC4 spine thickness ?
Does the spine taper in thickness from the choil area to after the jimping?
In another way: Is the spine grinded thinner in the area after the choil area where the actual "flat grind" is ?
I know the RC4 aint a real prying knife, but at least some prying strength can sometimes be an advantage.
Thank You in advance
It's the same thickness from the butt end up to about 1.5 inches from the tip, then it tapers down into the point.
thank you
Im asking because the RAT7 is thicker in the choil area than the actual blade
