IIRC Chris once told me they used 80 grit glass, that's what I have always used....there are some variables like air pressure and nozzle size but it's all good.....80 grit and high pressure works well, the aggressive beads can beat up the Ti.
Don't know what they use at factory.
Aluminum oxide matches factory finish, I use 70 grit, and buy from Harbor Freight. Be sure to protect contact surfaces.
Mark, what's your working distance with these beads?
I talked with Chris on the phone a couple of weeks ago about the blasting media CRK uses. He told me they've been using 60/80 for a number of years.
I called him to ask if CRK has ever used a fine bead blast finish on some of their knives. He said no. I have a large regular with a fine bead blast finish...it's not original.
Craig their are so many variables with beadbalsting it not really fair to say by the use of a particular grit that a finish could be precisely replicated.
Beads start at a particular grit and soon become another.
Beadblasters require more air volume that most other pneumatic tools and there Is a big difference between a garage set up and a commercial screw drive unit.
I consider Reeve's finish to be fine, look how easy it scotchbrites.
I have seen guys shoot them with carbide beads because they wanted a more aggressive finish.
I agree with what you wrote, and would guess that at that distance a lot of the glass beads may be fracturing, which would give a more toothy finish.
