Re-curve Bow Question
Hi all,
I only really get to scan these forums, but I've found this one to be suprisinly full of good info... So, I thought I'd ask a quick Q concerning a take-down recurve bow package I have found...
A catalog company I've bought from before has a recurve bow package, in a take-down style, in two sizes - medium and large if you will, with regards to over-all length. I have to admit, I haven't shot a bow in a long time, but given I could concievably make arrows under the most adverse conditions, as opposed to making cartridges for a gun, that I might want to add one to my home survival trove.
However, not being familiar enough with anything other than shooting a bow, do I have to be concerned with overall length? I'm 6' 1" with a 35" reach.
I was thinking that the shorter bow would be easier to pack, but the longer one has a slightly greater pull weight which I thought might be better for end performance...
Any help on my deciding out there?
Thanks in advance!
Couple of points.
The longer bows are generally more forgiving in terms of accuracy. Also, the shorter bow can cause "stacking" if drawn to excessive lengths. This means that the string has a narrow angle on your draw hand and can put pressure on your fingers and affect the shot.
You should get your draw length measured to help with your decision. I think every inch over the bows printed draw length will add 2 pounds to the draw weight, approximately.
At your height, I would tend to recommend the longer bow. But you should also make sure the bow weight is good for you, as being over-bowed will be counter-productive in terms of accuracy and enjoyment.
DPKnives just purchased a well-reviewed and affordable Sage takedown that I'm now considering as well. He and Mtnfolk Mike will be along to add their experienced input.
Enjoy
B
Measure your draw length, and see which one fits better. Take a meter stick, and stand just like you would if you were shooting, with your arm out. Rest the meter stick on your hand like the arrow, and draw back to your anchor point to find your draw length. Then see which one fits. What catalog company is this?
I'de say go with the longer limbs. Once it's broken down, the length difference will be cut in half, assuming the risers are the same length. Also, when measuring for your draw length, make sure your form is good. Perfect practice makes perfect. If you plan on making your own arrows, you might want to practice that, too. ;)
That Sage that Doug bought pulls real smooth, and I can't wait to shoot it.
Well said Roger, I would go with go longer myself. The Sage is a great value for the buck. It is very smooth to draw and shoot. I wish the weather would warm up some so I can get more time in with it. It has been a lot of years since I shot recurve and instinctive and actually have been shooting pretty well at it with just the little shooting I have done.
Roger speaking of making your own arrows it has been 3 weeks time to peal the bark and re-bundle. Doug
You're a tall guy... go long!
I'm 6'2" , 31" draw length, and my all-time favorite s-m-o-o-t-h shooting recurve is a 70" Hoyt Pro Medalist take down with 42# wood/carbon limbs.
Stay sharp,
desmobob
My 48" Bear Super Mag, is a twitchy lil' sum bitch:D. A big thumbs up for the guys at 3 Rivers archery and for longer bows. Longer bows are a bit more forgiving as mentioned. Doug,I too am waiting for the warmer weather, the Avon Bowman awaits;)
Hi guys,
Thanks for the input... I'll look into the Sage now that it's been mentioned....
The package I saw is from LLBean; http://www.llbean.com/llb/shop/5941...&cat4=1118&shop_method=pp&feat=1118-sub2&np=Y
It's inexpensive, and I doubt if I'll get to shoot it too much, but it's basically a thought with regards to long term availability... and fun if I get the opportunity to play with it. :D
I'll check back and see what y'all think...
Appreciate the feedback!
A 29# draw weight, and 28" draw length? I don't know how much good that would be to have in your stable if you really needed it. Nice target bow, good way to get started shooting. But my target bow, which I've had since junior high school, is a 45# draw weight, IIRC.
Yeah, I was kinda wondering if it would be really useful... But I'm getting on in age and figuring I didn't want to fight the bow, too...
Thanks for the input guys!
