Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
I have a great knife, some will argue but I'm set on this one quite well, with one exception, the handle. Over the years of hacking and chopping, which this has performed exceptionally, keeping it's edge no matter how many branches it's hacked off, but the rubber handle is loose on the tang. I've heard others complain on this point also and just figured I was lucky, but no longer. It's not real sloppy loose, but enough to bug me.
My intent is to remove the rubber handle and replace it with some walnut or ironwood, doing the hidden tang thing.
Now the question(s)...
Which should I attempt to try;
Mortise two pieces of wood onto the tang?
Drill a block and epoxy the tang inside?
On either method, how would you guys/gals do this? As the tang is quite wide, maybe 7/8" and about 5" long.
Maybe I'll need to grind down the tang to a narrower section but it's quite hard I'm afraid and I lack a belt sander anyways.
I want to end up with an Octagonal shaped handle with a slight curve downwards on the edge side, much like one made by Rob Hudson, as I've always enjoyed the feel his knives had.
I worry that the guard that is on there may be too narrow to keep the wood thin near it? The guard width is just a bit over 7/8" with the tang at 5/16" thick, the rubber fits just right to the sides of the guard but would the wood be too thin against this?
Maybe tapered down to the guard as it approaches that point?
I'm a worry wort I know, so help if you can...I'd rather not do slab handles but like the hidden tang approach, feels better I think.
Thanks in advance,
G2
Thanks in advance,
G2
