........I usually give them out as loner knives, when i got my clipper and my scout back, my god... The tips were chipped right off, major damage to the blade... ...
.........I tried to sharpen my scout by taking the course stone of the sharpmaker (using it like a benchstone) and pushing the blade untill the bevel was flat against the stone, and then rubbing it back and forth, it got it somewhat sharp, but not nearly razor sharp, and it scratched the blade very badly... .......
First mistake, Matt - Loaning out your knives!!! (
D)) If I'm inclined to "loan out" a knife, I'll just give it to the person to keep. Of course, that's just me
A few months back, a bunch of us Dads were working up at my duaghter's school, getting ready for the start. Anyway, I'm carrying my EnZo Trapper on my hip (a Scandi grind, coincidently), and a guy yells down from the second floor "Can you pass me up your knife?". I said "What do you need to cut?" and he says he wants to trim off some foam that foamed out from a cinder block wall. You know that stuff we get in a can and spray it into cracks, and it expands to fill the crack? Well, does anyone here (who cares about knives and edges) think I'm going to let him use my knife? Huh? No, I told him to come down and gave him an old Stanley utility chisel I keep in my tool pouch. I can grind that thing down - it's a utility tool. And even if he was going to cut something acceptable, I would've gone up to cut it for him. A guy can;t bring his own knife to a worksite? That tells me he doesn;t have a clue about the difference between a quality knife and a beater, or a sharp edge and a dull one.
The problem with stroking back and forth on one side is that you will rock the blade back and forth. Now, there are guys out there who can do it, but they've been doing it, through all the ups and downs, for some time, and it works for them. I say, for now, stroke in one direction only. Use a larger stone than a flat-lain Sharpmaker, if you have it. I like the waterstones because they cut very fast and are inexpensive. You don;t need anything high-dollar for the Mora or any Scandi-ground blade. Practice keeping the large bevel flat on the stone. Remember that, at the belly, you have to raise the blade slightly because you have a double angle there....a little geometry is all it is.
After your bevel is flat and ground-to-zero, then go to the Sharpmaker white stones, and just give a few whisper light (I mean whispery, ok? try it) passes, adding just the slightest micro-bevel. Then strop.
I don't see the point of grinding the entire bevel on a Scandi. ......
I suppose alot of guys do it the way you do, Hal, but the point is, really, to
maintain the Scandi bevel. Otherwise, it becomes over time a standard v-grind. And...in that case, why not just get a v-grind? That's the point of grinding the entire bevel, I believe.
Whatever works for each user, I suppose, but maintaining the flat bevel on a scandi is relatively easy. You're really not grinding away as much metal as it seems and, even if so (in the case of rolls or chips), then that's what it takes to keep a scandi-grind a scandinavian ground knife. Again, if not, then we should seek a knife with a different grind, such as a convex or a flat ground V. I mean, why buy a Scandi if we don;t want a scandi?
