Just thought I’d put this out there….
If you disassemble a stretch 2 xl (or really any lock-back), reassemble the handle and lock bar with spring (put the pin and screw back on the lock bar) before putting the blade back in. Don’t tighten the screws all the way, depress the lock bar while putting the pivot pin back in through the pivot hole in the blade.
If you try to go the other way, pivot pin and blade first, it’s not going to go well for you.
That is all. Thanks!
