- Apr 6, 2001
Ok, (HUGE POST AHEAD)
I know I should be studying for class tomorrow, but this has been bothering me all week. I am rebuilding the last of the Daisen defects, a 18" AK, and I thought yall would like to know how it is going.
I dremeled the bevel off the buttcap, stuck that end only in boiling water for about 30 sec using a waterproof ski glove on that hand to keep the steam from burning me. I then held it at an angle against the linolium floor and knocked the buttcap off with a screwdriver.
I then placed the other end of the handle in the boiling water for a few seconds and put the screwdriver imbetween the little gap between the bolster and the handle and wiggeled it off by working myself around it. This took 3-4 trips between the sink and the boiling water.
Hint: Laha STINKS :barf: Leave the windows open! :barf:
After the Butcap and Bolster are off I used a pair of channel lock pliers to GENTLY dunk the handle into the water, still using the gloves to hold the uninsulated plier handles. After another 30 seconds I went to the sink and with the glove on one hand and a small hammer I worked to get the broken tang loose from the handle by hitting the base of the tang, where the buttcap used to be. This pushes the tang about 3/8" forward. YOU CANT REMOVE THE TANG ON YOUR FIRST TRY! This is my second time to do this and it is better to be gentle if you want to save the handle. The Laha in the center of the handle is still pretty hard, so get the tang a little loose and put it back into the boiling water.
Now, since the tang is pushed slightly forward, try to get all of the air out of the little gaps by moving it around under the water with the channel locks. After about a min of doing this, take a pair of channel locks and pull the tang out using your glove to hold the handle.
You have now just disassembeled the Khukri.
Now the interesting part. If the handle was wood and if you leave it out it is going to dry and crack. Remember Walosi's trick with the Murphy's oil soap? USE IT. I smothered the sucker with it, and tryed to get some inside with a few Q-tips. After a minute or two wipe it free and clean out the inside with more Q-tips.
I found that the tang was nowhere near straight. As a matter of fact there was a small wooden shim near the portion of the tang that was closest to the bolster and furthest away from the 'wall' of the handle.
I am also going to let this sit out for and get some air till I can get back to it sometime Sat. afternoon.
One more thing....Laha dosent stick to Teflon, I used my good pots because I never use the large one and I figured "what the heck", however it leaves a greasy oil slick on the water and at the water line that is a real pain in the butt to scrub out. Right now I have boiled 2 other potfuls in it and it is soaking in soap water...I wonder if HIKV can be ingested too???
