First sorry for my English.
I have a steel bar from a caterpillar of a bulldozer, bar that joins the pieces of a caterpillar together .
It is about 25 mm (1 inch) in diameter and about 450 mm long .
I want to build a knife out of it.
The problem is that i do not know what steel is usualy used to make these rods in order to proper heat treat .
An approximate answer is welcome too , ex (about 7% of this + 8% of that, in alloy with this or that )
Why this steel? It is shock rezistent , abrasive rezistent , very strong and hard , and i have a lot of it.
Perfect for a good knife .
It is posible to make some tests , quench _breake_anealing to determine the type of heat treatment , but
It is time consuming and you are never sure if all 100% of steel qualities are used .
thanks
thanks
