I can't cut fancy contours because my mill is manual, not CNC... but I could probably lighten them up a bit depending on specifics.Any recommendations on who can mill out (lighten) solid titanium scales? I have three titanium folders which I would like to lighten.
Thanks much
I'm assuming the standard grade titanium used in making knife scales, either Ti4Al4V or Ti6AL4V.I'm a machinist and machine titanium every day.
its sweet sweet cutting. what grade titanium is it?
There's a bit of a difference between turning small barstock into screws in a Swiss screw machine versus hogging material out with a mill.well. I machine titanium for medical parts so it may be different. I use small diameter barstick in swiss lathes.
the tooling lasts quite a long time and dimensions dont move at all.
this is grade 5 Ti wich has the least pure titanium.
I know that pure titanium beats pretty gummy and sticky when cutting if theres not enough coolant or the soeeds or feedscare wrong.
glw your endeavour
Ti is pretty light already. Most of the milled Ti slabs out there are one the presentation side for show vs. trying to shave weight.I h*te that the Spyderco Techno (1, 2, 3, 4, just any) doesn't come with milled out Ti scales. They could have done it, but they chose not to. Maybe to cut costs?
Mako109 you could shoot Mike at Spectrum Energetics an email. they have a machine shop and offer services.
Especially since you'll be working with an already finished item.There's a bit of a difference between turning small barstock into screws in a Swiss screw machine versus hogging material out with a mill.
Something I do have, is a lot of tricks for rigidly mounting finished titanium items...you think Ti sucks to machine, you should try chiseling itEspecially since you'll be working with an already finished item.
You should do a timelapse video. That would be cool.Something I do have, is a lot of tricks for rigidly mounting finished titanium items...you think Ti sucks to machine, you should try chiseling it![]()
That's not been my experience. I find it tough and prone to work hardening. But then again, I don't even know what "g code" is.titanium is one of the easiest materials to machine.
anyone with any type of cnc mill and modeling program or g code proficiency should be able to do what you want.
titanium is eeeeasy cutting
