0.25”ID x 0.5” or 0.625”OD (both works) x 0.01”Thickness
https://usaknifemaker.com/washer-pb-1-4-250-inside-hole-diameter.html
It’s probably the same.Do you think that would be the same for the large Voyager series as well?
Thank you.It’s probably the same.
I tried 10wt and 85wt nano oil, also tried KPL, basically all the lube that’s the hype right now. I find that 85wt feels the best because there’s a lot of contact areas for triad lock and 85wt maintains the action the best. Lighter weight oil often feel dry after the while.Thank you.
Once they re-open and can ship washers I will get some.
Is there a suggested lube that works well with thesee washers?
Nice. I use 0.015” thickness and 0.625”OD for AD10, it has slightly thicker original washers. The new washers give it the Chris Reeve-like “hydraulic” smooth action.Today I changed out the original washers on 5 of my Recon 1’s, using the phosphor bronze ones. .625” OD fits nicely.
I also replaced the washers on 3 xl Voyagers, using .015” thickness PB washers. Everything fits well and operates smoothly after mineral oil. Thanks for the washer measurements.
