the 2016 Bob Marshall Open is quickly approaching and we wanted to get a good training/recon trip in this weekend into the Dearborn area
this year we want to try to mix a little running in so we revamped our kit around the largest running pack made- the Fast Pack 30 liter (made by Ultimate Directions), this meant really cutting our load down both in weight and volume
we packed everything we would take for a 3-ish day trip, including snowshoes- our packs were in the 15-17 pound range including food/water
we picked a 25-ish mile out and back figuring that would give us a pretty good idea if it was going to work
of course typically spring weather in the mountains- a combination mist, rain, snow and sleet, temps in the mid to upper 30's
the Dearborn is a gorgeous drainage with numerous waterfalls and deep cut canyons
about 6 miles in we forded the Dearborn
shortly after the ford, our route really starts climbing for a pass on the Continental Divide separating the Dearborn (east side) and Blackfoot (west side)- a mile or so into our climb we had to don snowshoes
it was a steep climb and we had several somewhat dicey avy chutes to cross
some really pretty Phlox popping up high
when we finally dropped into the Blackfoot drainage we still had a lot of snow to contend with along with numerous stream crossings
we weren't the only ones winding our way down the drainage, at our turnaround spot we found some really large grizzly tracks
we ate a quick lunch and headed back out
Blackfoot side of the pass
Dearborn side
we were socked in for most of the trip, but got a few good views on the way out
we stopped in at Augusta to the Buckhorn Bar for much deserved 1/2 lb bacon cheeseburgers and a pitcher of local IPA
were pretty happy with the packs, our hope is that in four weeks we lose enough snow that we can ditch the snow shoes- that would put our packs closer to 12-13 lbs
thanks for reading
Dearborn side
thanks for reading
