sand it down, soak it in kerosene for a few days, wipe off let dry, resand with smoother grit sandpaper, resoak in kero, then soak in linseed oil. Remove, buff with steel wool while wet and then wipe and hang up to dry
Kerosene is the modern version of coal oil. Coal oil was commonly used for tool handles during the 18th and 19th centuries. It was also used for soaking ramrods in. Not only does it waterproof, but it greatly aids in the flexability of the wood preventing breakage. This is especially true with Hickory. Also, a small dose of coal oil/kerosene was drunk to kill GI parasites, usually picked up from bad water.
Submersion would be nice and maybe quicker. To be more thrifty, wrap cloth around handle and saturate with kerosene. Wrap the whole thing with plastic wrap and forget it for awhile. It should get a good soaking that way. Extra ramrods for blackpowder have been left in PVC pipe with a cap at each end. The piipe is filled up with the kerosene and used over and over again to temper more rods. They don't seem to break as easily.When you folks say soak, do you mean submerge or coat completely? Thank you for the clarification.
