Recreating the factory edge on a Sebenza 25
Yesterday one of the Chefs i sharpen kitchen knives for on a regular basis decided to treat himself to a brand new Sebenza 25 from a well known Dutch knife shop.
As many here know the Sebenza is a beautifully designed & manufactured knife, and the model 25 may very well be considered the current king of the hill in the series.
Sadly the factory edge on the first example the Chef got to handle was just plain blunt, and upon inspection it turned out that the other 4 or 5 Sebenza's 25 that the shop had in stock suffered from a comparable bluntness.
To cut a long story short: in the end the Chef liked the knife so much that he just bought the least blunt one, while the shop assistant promised to contact CRK to see if the other knives could be sent back.
Anyway, today the Chef contacted me to ask if i could do something about the edge on his knife.
The first thing i noticed about the blade on his model 25 is that it seems to be ground a hair thinner behind the edge compared to previous Sebenza's 25 that i've handled and sharpened, and that as a result the edge bevels were quite narrow, even with a measured inclusive edge angle of 35 degrees.
The second thing i noticed (with my Victorinox loupe) was that the edge reflected light almost along it's entire length, and i couldn't even cut a piece of copy paper with it.
Now i think that the edge wasn't completely apexed, but with only my loupe to judge by i'm not 100 % sure.
In a conversation with the owner and also because the knife is brand new we came to the conclusion to give it a new edge that would resemble the factory edge as much as possible, and to make it seem as best as i could that nothing was done to the knife.
First i removed the blunt apex of the factory edge by cutting several times into a silicon carbide stone, after which i gave it a completely new edge with an experimental Rubber Wheel with 230 grit diamond powder.
Finally i removed the tiny burr with a Paper Wheel with 1 micron diamond compound.
The new edge again measures 35 degrees inclusive from heel to tip, survives a few cuts into my laminated test block without visible damage, and can still easily treetop the hair on the back of my hand.
I think the owner will be happy when he comes to collect his knife tomorrow morning.
Before sharpening:
After sharpening:
That is really nicely done, and faithful to the original (intended) design of the edge. Bravo on the great work.
Please apply for a job at the CRK sharpening department! I think they have finally found the guy, and it's clearly your calling!
If they make me an offer i can't refuse i will certainly consider it, but i think it's a lot easier for them to find someone in the US, :D
Very nice! I think you made a great choice in keeping with the original angle and factory look in your sharpening job. I have noticed that the last couple of CRKs that I have received haven't had the usual razor edge that they used to come with. Maybe they have a new sharpener??
Could very well be, as i see more brand new Sebenza's with less than shaving sharp factory edges than a few years ago coming in for a sharpening job.
Not only that, the edge angles can be all over the place, ranging from 35 degrees inclusive like on the 25 in this thread to 50/55 degrees inclusive on this model 25 i did a few months ago: http://www.bladeforums.com/forums/showthread.php/1188646-A-new-edge-for-a-Sebenza-25
(i measure each edge on every knife before and after sharpening with a Tormek WM-200 Anglemaster)
From feedback i do get the impression that 25's seem to hold a better edge than other Sebenza's.
My large 21 I recently did was not quite 20 on one side, maybe 20.5, and closer to 21.5-22 on the other side. The slightest of a larger bevel on that side since I went with 20 dps, but it doesn't bother me. Went with 1000 grit plus a few swipes of a KnivesPlus strop block and created a nice sticky edge that has worked great through a lot of heavy cardboard work I've been doing lately for spring cleaning.
