Cliff Stamp
BANNED
- Oct 5, 1998
This started off as a rusty hacksaw blade which was found outside which was buried under snow for most of last winter :
A 4.5 angle grinder was used to clean off the rust, apply a primary flat grind, shape the tip and taper the tang. The flat grind was done under water. This took about five minutes. It was then epoxied betweep two pieces of pine and left for 24 hours.
The handle was then chipped to rough shape with a Byrd Finch and then the blade grind was refined on a belt sander which also rounded the tip and shaped the handle. This took about five minutes as well.
I was hoping it was a HSS blade, but no luck, this was carbon, but still, it only takes about 10 minutes and you have a small utility/paring knife. The knife is really thin, it is only about 0.02" at the spine, 0.005" goes way up on the blade.
-Cliff
-Cliff
