I've been wanting to see how the karda and chakma that came with my horn handle WWII would look if finished.
The horn and steel are roughly finished, with a slight flaw in the karda handle - sort of a long, low area with a slightly lighter color.
Here's where the refinishing stands to date:
Handle:
filled the low area with black 2 part epoxy.
sanded the area flush with 200 grit paper.
did a second coat of epoxy to fill the small areas.
progessive sanding with 200 grit, 400 grit and 00000 steel wool.
Still need to put the final polish on the handle.
total time - maybe an hour, not including drying time.
Blade:
started with 200 grit paper and sanded for about 15 to 20 minutes per side. this removed the deep scratches. I'm planning on finishing with progressively higher grit papers to get a finish similar to the Khuk itself.
That's about as far as I've gotten, but the karda already looks much better. Any ideas are welcome!
Patrick
Handle:
Blade:
Patrick
