Just to see what would happen, I took my grandmothers old machete and reground the edge. Essentially, I took a normal GI type machete and added a primary and secondary bevel. The primary bevel is 5/16" wide, on 1/16 thick stock, so it's somewhere between 3 and 4 degrees. Then I added a secondary bevel at 19-20 degrees. The secondary bevel is a little less than 3/64" wide, and 0.025" thick at the top of the bevel. After sharpening, I proceded to chop a 4x4 in two, and the blade would still shave my arm, in the area of impact.
The thing that bothers me about the whole regrinding session is that the edge on a large chopping knife is thinner than the edge on my Delica by about half (0.047" vs. 0.025") and it does it's job with no damage. My Delica is a couple of years old and has seen some heavy use. It has been sharpened many times. The question becomes though, how thin could I go on a pocket knife before I start seeing damage? I do all sorts of stuff with the Delica, from cutting wire, scraping rust off pipes, trimming threads, kitchen use, whittling, cardboard cutting, etc. Looks like this weekend I'll be regrinding the Delica. Hopefully, I'll be able to finish regrinding my Kudu as well. It took some damage and was being reground from that. Might as well thin it out while I'm at it. As long as I'm wishing/guessing, I might as well shoot for as thin as I can manage, say 0.010" or less with 15 degree bevels.
