- Mar 2, 1999
Well, I finally assembled my forge last night. While the clay/ash/sand started to dry, I messed around with my propane venturi. I've built one other before with a partner, and his used a welding gas-type regulator.
Mine uses the standard propane regulator and does not appear to get enough pressure. I use the #60 hole drilled in a 1/8" pipe nipple to feed the venturi.
Can anyone suggest options to get the flame pressure up? Can I safely remove the regulator, or should I replace it with a welding-type? Should I enlarge the #60 hole?
Thanks!
Mike
Thanks!
Mike
