gentleman_edc
- Sep 19, 2021
I recently went trough a purchasing srpee of old folders (Boker, Schrade, Camillus, Imperial, ...) and have been cleaning them up for use.
I've done a decent job, but I'm wondering if I'm missing anything.
My general process is:
* wash with soap and water, get the grime off and out,
* use a q-tip with rubbing alcohol or toothpick to scrape out the liner and get it clean.
* dry thoroughly with a paper towel
* Hit it with a liberal amount of WD40 to dry out any moisture and penetrate the pivot and backspring.
* Exercise the blade to loosen the grime in the spring. Leave the blade at 1/4 or 3/4 stop and use a paper towel to clean the side of the spring.
* repeat the past two steps (wd40 and cleaninging the gunk) until gunk stops coming out.
Then comes sharpening (and this can be a challenge).
* identify where the problem spots on the blade are. usually the tip and the near the choil, though sometimes there are nicks and blunt spots in the middle of the blade.
* Address the problem spots. Until this effort, I had never used an extra course stone on a knife, but years of sharpening had left a lot of extra material the choil that I wanted to work down. Some of these knives had blades that looked like recurves. I tried to get rid of a lot of this material. Using a Course stone to get a burr all the way around. I never new blades could get so dull, so at first I tried to just start with medium (lansky medium stone) and there were often spots I couldn't get.
* Continue the sharpening up to fine.
* make sure the knife is well oiled.
At this point the blades are usable, but some of the Carbon Steel blades had thick patina (caked on sections) which I used a strop to remove the bulk of (probably not the best tool) hopefully to prevent any expansion of the spots. I'm not sure if this was necessary, but I wanted to stabilize the oxidation.
The staneless steel blades are a bit more challenging. The oxidation on them is much harder to address. These are the spots that look like Crazing or Snowflakes of rust growing in the blade. I've buffed and removed as much as possible, but was wondering if there is a way to really clean them (chemically or electricaly) or at least try to stabilize them.
Is there anything I'm missing or doing wrong?
Also, I have a couple of questions on handles. I've purchased knives with serviceable handles, but is there a way to replace scales on these older knives. I know it isn't cost effective, but it might be fun to play with. And a Boker specific question. What can you use to replace the lost Boker shields that seem to be a common occurance?
I thought there would be a pinned topic on this but I couldn't find an old topic with my limited searching.
