- Aug 17, 2000
I've started carrying my REKAT Savant again for some reason. I've had it for a year and a half now and thought I'd share my thoughts. I also have a REKAT Pioneer II that I carried for over a year prior to getting the Savant.
This is/was REKAT's best work IMO. Had they brought the Savant out instead of the Pioneer II and applied the contruction methods to the other knives in their line, they might still be around (ok, and if they promoted their wares and got them into shops).
Construction:
Prior to the Savant, their knives were constructed using steel liners with G10 scales. The lock is their patented Rolling Lock (you can research that if you're not familiar with it). The Savant differs by using Aluminum for the body and smaller, decorative G10 scales. The Rolling Lock is retained. The blade is ATS-34 and .125" thick. I have the clippoint model. The pocket clip is oriented tip up and is attached to the G10 scale (screws go through scale and into frame). The Pioneer's clip was attached to the blade pivot. The Savant has dual thumbstuds, the Pioneer had one. The Savant's shape is much more "ergonomic" than the Pioneer. Being much lighter, it no longer feels as "bulletproof", but has been plenty strong for my EDC chores.
From what I read, the plan was to offer the knife in different colors. Mine is black with a black coated blade. I would have purchased a red/stonewashed version, but it was never made available.
Remarks:
The Savant is the smoothest REKAT I've ever handled. It was smoother NIB than my Pioneer was at any point (even after I polished the friction surfaces). Over a year later, it is smoother than ever and almost as smooth as any linerlock. If I hold the Rolling Lock slide back, I can flick my wrist and open this knife without the thumbstud. With the action this smooth, you would expect some blade play, there is none. It is completely tight laterally and up/down. I have not modified this knife in any way. It is every bit as smooth as a Crawford Carnivour (the custom, not the REKAT version)I handled once (which was the first truly smooth Rolling Lock knife I had seen).
I don't know what the RC rating of the steel is, but it's certainly adequate. It doesn't hold an edge quite as well as my Pioneer, nor does it seem to get as sharp, but it's no slouch either (for the record, my Pioneer seemed to be exceptional in this regard). This could be as much a problem with my sharpening method (and lack of time to do it right these days) as the steel itself.
I'm not crazy about blade coatings, but this one held up reasonbly well. It has worn some on the top edge but the main body of the blade is intact. The coating on the pocket clip has worn off on the edges as well.
The lock has worked quite well for me. A few light spine whacks showed that it works as advertised. I'm concerned about the spring used in the lock mechanism. I had one break in the Pioneer after a year. REKAT sent me a new one for free, but they're no longer around to replace this one. It's a plain coil spring (smaller than the one in a ballpoint pen though). I could probably find something to take it's place.
One of the issues with my Pioneer was a blade stop pin that was too short. It would rattle against the G10 scales until I glued it into place. The Savant does not suffer from this.
Conclusion:
This is a great little knife. It's not flashy or even particularly attractive, but it functions very well as a package. I would recommend it to anyone without hesitation. My only complaint is not being able to get it in the color combo (at the price I paid for this one).
Like I said earlier, this is the type of knife they should've offered instead of the Pioneer II. Imagine a Sifu or Carnivour built like this...
BTW, this is the only daily carry knife that has managed to hang around this long. Most are sold/given away within a few months for various reasons.
Chris
Construction:
Remarks:
Conclusion:
Chris
