Monofilament line needs to be tied with knots suited to the purpose. Common knots that you might use in rope may slip undone or cause the monofilament to break easily. And it seems that most knots tied in monofilament will weaken it to some degree (say 5% to 55%).
I have tested various monofilament knots. Not by pulling with a spring balance, but by tying two knots in the same line and seeing which one breaks first. The one that doesn't break is the winner.
I have been surprised at the results at times. I've also been surprised to have knots that have generally been very successful fail unexpectedly. Perhaps there was a weak point in the line, or perhaps various knots suit some brands of monofilament better than others.
And although we are often told to wet the knot before snugging it tight, I've found that sometimes a knot seems to be stronger when it wasn't wet (although I pull it tight slowly to help avoid friction).
I'd be interested to hear the views of people who are experienced with tying fishing line.... what knot is best for terminal tackle... and especially what knot is best for joining monofilament line.
The knot that joins any line should be the strongest knot possible. If you get a break in the line at all it is best that it breaks at the hook. That way the fish has a chance of surviving without dragging around a heap of line. The hook may rust out eventually (at least that is how I comfort myself). There is far too much rubbish in the environment without fishermen adding random lengths of monofilament because a joining knot broke.
Sometimes I will cut and re-join a line many feet from the end of the line. I will do this if I think it is necessary to cut out a tangle or a weak spot.
So.... what is the strongest knot you know of for joining monofilament fishing line?
Thanks in advance..... Coote
