Hm, i´m not a veteran. But for me, it depends on what i want to cut with the knife.
I got two razor blades wich are as thin as possible, by relief and edge. But i only cut my barb with them, nothing else!
I got a BM 812s, wich i found is quite small, not to consider it to "hard use", so i grinded the bevel in the way i take the knife for fine cutings (something between 10 or 15° not included).
My 806D2 came with a bevel around 15+°. I gave it to a prof to get it up to 20°. Just because i want the material over the edge (he is grinding by hand, so the edge is somehow convex), if i got a knife with a strong (thick) blade. It will never shave any hair, but it cuts from newspaper up to hard wood (and maybe will open cans for me) and holds its edge for long. If i would take a smaller angle, i guess reprofiling would be the most time i spent on the knife.
As long as nobody can definatly tell how strong steel grades are, i use to think, to have a stronger than average steel (D2) and follow those old fashioned instructions on edge bevelling. (On that day, when someone can proof me, that D2 has the double strength than AISI 420, i might set the bevel back)
So, my question back to you is: What do you want to cut with the knife and how shure is it, that you lead the knife without twisting?
This would determine, how thin a bevel could be.
JMHO.
