- Jul 26, 2010
I have posted this else where also, but thought I would throw it up here to see what happens: Cheers
I have inherited my dads 600 in .350 and upon further inspection, cleaning, fondling and getting it ready to use I have started to notice some issues. Two to be exact. I knew about the triggers issues and this has been resolved, these issues are feeding and bolt related. Here they are:
1 - Bolt is very hard to close when round in chamber.
This happen regardless of the round being feed from the magazine or just sitting on top of the follower. And regardless of handload or factory ammunition. When the bolt face is inspected there are small brass shavings under the extractor lip. The ejector pin seems to work fine. The base of the cartridge, where the data stamp is, has a light scratch, about halfway between the primer and the outer edge of the rim, that has the same radius as the shell. The edge of the rim look quite roughed up.
Questions:
- how stiff should the ejector pin be? I think a deep bolt clean is in order.
- how can I tell if the extractor is bent or messed up?
- Or is this a head space issue?
2 - Rounds Catch on the way into barrel.
This only happens when a round is cycled from the mag box. Not exactly sure where it is catching but upon examining the brass, there are long scratch marks, the basically run from the tip of the bullet, down the neck over the shoulder and down the body of the shell. They are not that deep, but noticeable for sure, you can also heard a metal on metal noise. It has to be happening somewhere between the front of the mag box, just past the front edge of the follower and the leading edge of the barrel. I can't seem to pin point exactly where the problem area is.
Don't really have any questions on this one, just looking for advice or perhaps someone has had the same issues.
Cheers and thanks
Questions:
Cheers and thanks
