Remington R 4 Knife
Your thoughts please on the Remington R 4 Scout knife. It's been mentioned in a few posts recently and I'm thinking of getting one.
How does it compare to the Vic Farmer? It looks like it is about a quarter inch longer and has an extra blade.
Any additional information on the R 4 would be appreciated.
Thanks,
Raja
My R-4 is the same length as what I believe is an Alox farmer (awl, spear, saw, can opener and bottle opener). R-4 is a little thicker and wider. R-4 has a coping blade (nice) instead of an awl (which I miss). R-4 saw is a little thicker and has a shorter toothed section (ca 3/8"). R-4 has a lanyard shackle peened onto the pivot pin, instead of the split-ring lanyard bail of the Vic. I don't feel much difference in weight.
The R-4 has a larger grip, which I find to be far more comfortable for extended use, and is also more secure. The texture of the delrin scales is less slippery than textured alox. The main blade is quite a bit wider, which will hold up to more sharpenings. Your index finger sits right between the pivot and the tang of the main blade, helping to keep your finger from accidentally sliding down onto the sharpened edge. The R-4 has sweet brass liners. I prefer the comfort of a bail over the Vic key ring. The coping blade rocks. Made in USA, baby!!!
The Farmer is a bit lighter, and the design is more compact, making it easier on the pocket. The Vic has better fit on all tools (never any blade wobble. Swiss precision!!!). It has a longer and finer toothed wood saw. The can opener doubles as a philips screwdriver. The cap lifter has a half stop. Best awl on a knife ever. You can't accidentally close the main blade on a keyring, the way you can with a bail. There is a wire stripping notch on the cap lifter. The whole design is less likely to rust, and extremely robust.
In the end, they're both great Knives. I prefer the R-4 for extended use, as it's much more comfortable in the hand. Also, if I were outdoors under harsh and stressful circumstances, I'd feel far more safe using the grip on the Remington. And I love having a secondary blade with a flat edge. On the other side of the coin, the Vic is nearly indestructible and the construction is more elegant and precise. It's much more pocketable than the Remington. The philips and awl are very handy tools.
The Farmer has great tools and a good blade. The R-4 has two great blades and some good tools.
The R4 is thicker and not as pocketable as the farmer. I have both and always grab the farmer when headed outside. But I love the look of the R4. It's a beauty
Thanks for your responses; I think I'll order one. I also carry an Ulster Scout knife, but miss the saw.
Buzzbait, thanks for your thorough review and pictures. I've enjoyed reading your reviews for several years, going back to the excellent comparison of the Sebenza, Benchmade 710, and Spyderco Military.
Thanks,
Raja
I own a few of both. All the replies above are spot on, especially having the 2nd blade. Buy one and rotate them. It's a win - win.
