- Aug 27, 2014
Im looking into getting a TOPS Knives MSK for neck/pocket carry and Im curious if the micarta handles come off for cleaning. Also if any of you have owned this blade, how have you liked it?
Well, there you go. :thumbup: I wonder if you could replace the tube with a chainring bolt that would still let you slide a lanyard through, should you wish, but would allow quicker and easier disassembly? Might be hard to find one that's just the right size, but it would be worth looking into.
Once you remove it the first time it's easier from then on...you'll experience one of 2 scenarios...1 you'll remove both scales and the tube will remain on the tang, this usually won't effect the flare much if any...2 the tube remains stuck to of scale and will then need pulled thru the tang which will likely mess up the flared end.Well, there you go. [emoji106] I wonder if you could replace the tube with a chainring bolt that would still let you slide a lanyard through, should you wish, but would allow quicker and easier disassembly? Might be hard to find one that's just the right size, but it would be worth looking into.
