Remove "clip insert"
Hello friends.
I want to remove the "clip insert" of my Small Sebenza and I can not, this very tight. With the normal clip by pulling it easy but with the "clip insert" not how to remove it.
Any idea?.
Thank you.
I had this problem with one of mine for some reason too, which was odd because I have several that removed with no issues. Anyways, I used a plastic scraper from my wife's kitchen drawer to pry it out. It came out with no scratches, just be careful or you will bend the clip insert.
You can pry it out with something like a t-15 trx bit or hex-key. Just put that in the hole in the insert and pry it out, or at least get it moving a lift it off with something a bit softer. There is no thread to damage on the insert but the Ti will deform if you rag on it so be a little carefull. :)
Thanks for the ideas.
That's what I'm doing, but this very hard. I'll keep trying.
Thank you.
You could also try the same trick as described above, but put it in the freezer for a few hours beforehand. Get it nice and frozen, and it just might come out fairly easy. I'd maybe put in a ziplock bag first, to keep any moisture from getting in the cracks and freezing. Just a thought..
