Yes it's mirror polished.You sure it's mirror polished? Plenty of kuks were chromed.
I would think that if its rusted, you are already past the point of preserving any sort of polished finish.....Tell me the ways to remove rust without damaging the mirror polish?
please mention least harmful ways.I would think that if its rusted, you are already past the point of preserving any sort of polished finish.....
Without knowing whats actually going on that will be pretty hard to do.please mention least harmful ways.
Also the easiest
rust spotting that is surface only.....a pencil eraser works. won't work on pitting or deep rust.
Try Machine oil and a piece of hardwood and rub it off
Thanks. Also can you tell what's the easiest and best method to stop the khukri from rusting? I live in a very humid placeIf it's already mirror polished, continuing to mirror polish with a buffer will probably remove the rust unless it's deep. I have done this many times to restore a mirror polish that has minor surface rust. Green or pink compound will help.
Sam![]()
Thanks.Flitz works great for surface rust removal. Use a microfiber and test it out. For storage, to prevent rust you can use a beeswax compound, wicked edge sells one that’s blade specific. I’ve also used frog lube.
Try flitz, or look into stainless modelsThanks. Also can you tell what's the easiest and best method to stop the khukri from rusting? I live in a very humid place
