Remove surface rust??
Hi Gang! What would be the best way to remove light surface rust without desturbing the metal much:confused:
Flitz. If you live in a humid environment, you'll want to buy this stuff in bulk :)
Dremel buffer/polisher and some chromium oxide (CrO) which you can get at almost any hardware store/depot.
I use 0000 steel wool and WD 40. Steel wool is not hard enough to hurt a knife blade. Bronze wool is fine, but is harder to find.
A Dremel with buff/compound can over-polish, and change the look of the knife.
Simichrome and Flitz will work well, but do some polishing of their own. Steel/bronze wool will only attack the rust, not the blade finish.
Bill
