The coating shouldn't affect cutting ability. I understand what you mean about drag along the main grind. If it were me, I would just take extra fine steel wool and smooth the blade. The coating as Terrill said helps protect from rust. Just a thought.cucharadedragon said:Just never have liked the black coating, but I also make the assumption that maybe it doesn't slice or cut as well with maybe more drag. This is only an assumption so please correct me if I'm wrong.
Close, but no cigar. It's actually a Recon Scout. The Trailmaster is quite a bit longer.that is not an srk in the stripped pic. its a trailmaster.
Paint remover works on Beckers just fine. Turns it into a black goo that you can scrape off with a razor blade. A little work with sandpaper will take off the greyish stain that remains. Be prepared for a rough finish under the black though, it takes a bit more work to get that better but the results can be very impressive.I'm assuming that the paint removers would work on the Becker coatings also?
