I sometimes use my strop with green compound at the end of the bevel (blade edge not even touching) to remove hand sharpening mistakes where my coarser stone got beyond the bevel. However, the original finish is compromised. If the scratches bother you get them off with; Flitz, it may take time, but it will do it, really fine grit sand paper (Skimo is right) 800 or finer, or a strop with compound. Make sure you rub in a direction that is desirable, the scratches you have do not look good. It would be cool to create a rough finish of perpendicular lines on the grind with a really large diameter wheel, and then polish the spine area where the blade is un grounded, just a thought, but it obviously would not be original finish. The most important part is that you have fun doing it, and are pleased with the outcome, regardless of our comments, opinions, or conclusions.
