How do you makers remove excess epoxy glue from your handles?
When I epoxy my handles onto the full tang blade contruction, glue will seep out of all the crannys where the wood, guard and blade come together when compressed in the vice.
Normally I just let the whole thing set overnight. When the glue is set, usually it is fully set hard. My prefered method of removing the glue from the blade and other unwanted areas is to either gently heat things abit with a torch, or together with heat generated from grinding the handle down.
Once things are warmed up but not too hot, I take a small chistle I made from solid brass and scrape off the glue. With brass being soft it will not mark the hardened steel. It works quite well, especially if the glue has not set fully. But often it is already rock hard and needs some gentle heating to scrape it off.
What other methods do you use?
