Originally posted by hogman
In any case it appears that the ends of the pins are solid steel, not hollow brass. This may be because I've squeezed them together with pliers and it caved in though.
Well, in proper engineering terms, you're close to FUBAR. But not quite there. Good chance you've mushroomed it in the gap space between the handle and the tang. Time to find that jeweler's saw, and cut the pin on the other side if you can.Originally posted by hogman
Well, I hacksawed the end of and punched out one pin, but the other pin I had punched through to the blade without grinding down the head, so it is stuck against the blade.
Glad it wasn't near FUBAR. And if you really want to find out if it swings as nicely as the BM 49-SPL (would you consider a 49-01 instead?), next time you're in the NYC area, give me a holler.Originally posted by hogman
It took me two years to do this one knife, but now it swings as smooth as the 49-SPL I wish I had!
