Removing Light Scratches
What is the best way to remove very light wear marks / scratches from a satin or doublecut finish blade, without a trip to the factory?
Thanks! :)
For satin finish just use a high grit sand paper (1500 , 2000 , 2500 grit) . I don't think you can do it to a double cut finish .
for double cut touch-up ya need a pair of teeny tiny ball peen hammers... and a smaller pair.
use a scotch bright pad, try medium grit, i believe thats how the factory does some of there clean up.
double cut has to be blasted with some 140 seive glass beads at about 30 to 50psi.
Mr.BadExample said:
they're not scratches, they're like wrinkles... "character marks" :) don't use botox on 'em!
damned straight!
you know damned good and well that you can't mix botox with viagra! :eek:
