removing logo
i'm not exactly sure were to pst this, but what is the best way to remove the harley-davidson logo on the blade of the benchmade nagara with out ruining the finish on the blade
You might try polishing it off, either by hand or with a Dremel. 2000 grit wet/dry would be another faster option with minimal risk. I used both methods to remove "CHINA" once.;)
Whatever method you use will probably leave a faint ghost if it was applied by laser.
I'd be more worried about the blade hyperextending
past 180 degrees, don't think it's s'pose to do that.
While Benchmade fixing it under warranty maybe they
won't mind removing the H-D logo for ya. ;)
Good luck removing the logo. I wished Benchmade would give you the option if you wanted the logo or not. I'm not a H-D fan, so the logo is one reason I would not buy the latest Nagara's.
There is no way of removing the logo that I've seen other than elbow grease and sandpaper. Dremel will remove it, but you probably wouldn't like the results.
I suppose a buffing wheel may work as well with more uniform results than you could expect from a dremel.
The Nagara is such a lovely suave gentlemen design and it pains me that it's ruined by this big font text on the blade. I'm happy that I already have the original Benchmade-branded version
yeah thanks for all the replies and i'm really not a harley davidson fan so that is what is holding me back from getting it
Is it me or is that blade closing/opening in the wrong direction? :confused:
