- Dec 14, 2010
Hey Folks,
I have a knife I have been forging on. I want to do some file work on it now. I was told to get the scale off of it first. To do this, I was told to soak it in muratic acid for about 20 minutes. Looking at some search results here, someone suggested vinegar over night. So which would you use?
If you would use the muratic acid, what is a good ratio acid to water to mix up a batch? The instructions suggest very little acid to the water. Then just add a little more acid to the water until the concrete starts to bubble. (cleaning concrete)
If I use the acid, can I wrap a piece of copper wire to the blade to lower and raise it into and out of the acid? If not copper, stainless steel wire ok? I'll have it in a PVC tube with caps.
Thanks
Thanks
