Is there a preferred way to remove scratches from most Spydie blades? My preferred way to do this for flat grind blades is sandpaper on a flat surface. 500-800 grit wet generally works, maybe follow up with something finer when needed. Unlike a belt this allows me to go slowly and allows good control over how much material is removed.
The problem is this also removes the spider logo from the blade. I really wish it was slightly engraved rather than printed, which would solve this problem.
Maybe a Dremel polishing wheel with some polish around the logo? This may work, but then I get differential polishing on the blade. Looking for a better option.
